rcsimpson
Aug 03, 2016Follower
Help -New Router killed extender use
My range extender worked great for 2+ years. THEN I changed routers. I've tried the factory reset - I've tried connecting an ethernet cable to the extender - every method i've found on line to get...
IlCongre
Aug 03, 2016Aspirant
Io ho un problema simile. Mi connetto a mywifiext.net e avvio la procedura di collegamento all'access point, sembra procedere tutto bene ma alla fine viene sempre fuori un errore che non permette di finalizzare la procedura.
L'access point è un plw1000. Col vecchio av200 nessun problema...
- DarrenMAug 05, 2016Sr. NETGEAR Moderator
Hello rcsimpson
Make sure you are holding the reset button for 10 seconds when doing a factory reset also try changing the wireless channel on the router.
DarrenM
