Tenkage's avatar
Tenkage
Initiate
Aug 25, 2020
Help connecting WiFi Range Extender
First of all, I don't have Nighthawk Mesh, I just didn't know where else to ask. Do the router and extender have to be the same brand? I have an old d-link router, but a Netgear extender. Anyways I c...
  • plemans's avatar
    Aug 26, 2020
    You can mix/match extenders/routers.
    The only issue is that sometimes wps setup methods don't work.
    Is that how you set it up?
    If so, factory reset the extender and install it using the installation assistant instead.
