Captdana
Jun 18, 2016Follower
How do I enhance my reception? PR2000
I live on a yacht and use Marina wifi to connect to the Internet. The PR2000 has been a great added layer of security for me. Also in some marinas you need a separate password for each device, with this I only need one. My problem is sometimes I am to far away from the transmitter to get a good connection. I have an external wired antenna that does a great job but it can only be connected to one device at a time and not at all to my phone.
I noticed USB ports on the PR2000 but can't seem to figure out if I can use the antenna with it.
Any ideas even if it means getting another set up?
thank you
Capt Dana
1 Reply
Get a range extender that supports Access Point (AP) mode and plug it into the Ethernet port on the PR2000. Most Netgear range extenders will work, except the WN2500RP. Be sure to verify support for AP mode by checking the manual online. You can also use a router as an Access Point.
