LasseBl's avatar
LasseBl
Initiate
Jun 30, 2016
How do I extend the wifi range?
Hello,
I have just installed the Netgear wifi extender (EX6120) according to the instructions. When I have the extender in the same room as the router it works well. All 4 lamps light green. But when I place the extender downstairs about 3-4 meters from the router the routerlamp lights red. The other 3 lamps light green but when I test the computer the wifi signal is as low as without the extender. I have placed the extender upstairs in another room 2-3 meters from the router and all lamps light green. I cannot get the router lamp to light orange. Please inform me how to get better signal downstairs.
  • Hello LasseBI
    You may want to change the wireless channel on your router to find the best signal for your home. Also you may want to factory reset the extender and then do the setup again in the place where you want the extender to be.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello LasseBI
    DarrenM
    • LasseBl's avatar
      LasseBl
      Initiate
      Hello DarrenM,
      First I will see if it is possible to change the router channel?? Then I do a new installation of the extender.  Do you mean to place the extender downstairs already during the new setup?
      //LasseBl
      • DarrenM's avatar
        DarrenM
        Hello lasseBI
        That is correct and then if you cant get a signal slowly move the extender to other outlets until you find a good spot where it can get signal from the router and supply better signal to the basement. As for the router channel it would be in the wifi settings of the router.
        DarrenM
