paul4ut
Jul 17, 2017Follower
How do I know if my wifi extender was installed correctly?
I went through the steps to set up my Netgear wifi extender (following a video tutorial on YouTube). At the end, it appeared to skip the last step, but I'm not sure.
How can I be sure it was set up correctly and is working properly? Is there a utility or method to check if it is operating? Thanks.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello paul4ut
If you are able to connect to the extender and you are receiving internet you should be fine.
DarrenM
