helpmeNetgear's avatar
May 06, 2013
How do I remove or block this device from getting my wireless connection signal
hi I have an N600 Wireless Dual Band Router WNDR3400v2 and I'm looking at my Net Gear genie an device that is not my own I don't even recognize it and its getting my network connection how do I block this or remove this device?
  • go to your Genie, under advanced tab
    > administration
    >attached devices
    >copy MAC address of your computer/devices
    >go to advanced set up
    >wireless setting
    >click on the setup access list
    >check "turn access control on"
    >add the MAC address of your OWN devices
    >click apply
    With this you will only have your own devices connected to your wireless network. If your friends want to access your network, you can manually add their MAC addresses so they can connect.
  • If you don't have wireless encryption configured, you need to configure it and set a strong encryption key, if you have encryption configured, then you need to change the key - of course, you'll have to enter the new key on all your connected devices, and I'll bet, that whilst doing this, you'll discover that the mystery device, is in fact, yours.
  • You will need to use WPA2 encryption and disable WPS
    MAC Filter by itself by no means of security at all. This feature is to control the devices which has access to network but if you have weak encryption someone can HACK the encryption and SPOOF the mac address
  • I have WPA2-PSK :confused: and I have change the network security key once to an different name but apparently the network genie tells me an new device has enter I could disable or enable on the network map I don't see how and the unrecognizable device appears 2 times now
  • Change the encryption key, and add your devices one at a time - you'll find out what it is that way.
