Dino1956's avatar
Oct 01, 2016
How Do I Set Up 2 Netgear WiFi Extenders?
I have 1 Extender set up and it has worked great for 2 years. This one is extended from my AT&T Netgear 7550 Router.
I just purchased another extender. During setup, I would like to extend it from my Router just like I set up the first one.
The trouble is, it's saying for Security on my Router it has WEP. This is not correct. My Router's Security is WPA2.
So I have no choice but to extend the Network from the fist Extender. I'm not sure I will get a strong signal setting it up in a daisy chain.
I would prefer both Extenders to extend their Network from the Router. Again, I'm 100% positive my Router Security is WPA2, not WEP.
But in the mywifiext browser set up, it lists my Router as being WEP.
  • What security is your 1st extender using for its Wi-Fi?
    The challenge with using 2 extenders is that they must broadcast a different SSID than the main network.  Otherwise, they might try to connect to each other.  Daisy-chaining them is also not recommended because the performance drop will be severe.
    If you can, you should wire the extenders to the router and set them to Access Point mode.  This is the most efficient setup.
    • Dino1956's avatar
      Dino1956
      Tutor
      The 1sr Extender is WPA2. And I have the 2nd Extender daisy chaining off the first.
      Which is my only choice, after hearing your reply. There is no possibility of wiring them to router and to each other.
      I wish it would at least give me the option to extend both from the Router.
      But again, it reports my Router falsely having WEP security.
      And If I had an option of running Ethernet cords, I would no longer need the extenders.
      I would just run 2 lvery ong Ethernet cables directly from the back of my Router.
      But, why is it giving me false info on my Router saying it's Security is WEP?
      That to me makes no sense what so ever. Sounds like a glitch in the software.
      Thanks for your suggestions. I do appreciate it.
      P.S. I thought I saw somewhere in the community a post about someone running 2 extenders, extending both from the Router with success.
      That's really how I planned on setting it up originally.
      • TheEther's avatar
        TheEther
        Guru
        You misunderstood me.  You should not daisy chain extenders.  But in order for extend both from the router, the extenders must broadcast a different SSID from the main router.  Are you doing that?
    • Dino1956's avatar
      Dino1956
      Tutor
      I have Factory Reset both including my Router.
      This time it allowed me to extend both from the Router.
      And it showed my Router did in fact have WPA2 Security.
      I have one extender into a Wall Plug near my Apple TV.
      It's so close I put an Ethernet cable from Extender to my Apple TV.
      Everything was working well for a while and then...
      My Apple TV would not connect to the Apple Store.
      So I tried Netflix and that would not connect either.
      So I took the Ethernet cable out and connected Apple TV to Extender Wirelessly.
      Still no Apple Store or Netflix. When I got fed up and disconnected both my Netgear Extenders.
      I went to connect Wirelessly directly from my router and guess what?
      It said I needed a WEP number. So I had to Factory Reset my Router and am right where I started.
      No extenders. WiFi from my router only.
      This has been a nightmare. Something in the extenders causes my router to be seen with WEP security, even though it is not set up that way.
      I check with my browser going to 192.168.1.254 and security is ALWAYS set to WPA2.
      I have DSL with AT&T. I'm considering drilling holes in my wall and running long ethernet cables directly from my router.
      This has been a very frustrating experience to say the least.
      Oh yea. I also updated the firmware on both Extenders. And Btw, the router ia a Netgear AT&T 7550.
      So what's next? When I come to think of it, my router is not very far from my Apple TV, maybe 45 Feet.
      And it use to get a good signal before on my Apple TV, up until I installed my first Netgear Extender.
      This should not be THAT hard!
      • DarrenM's avatar
        DarrenM
        Sr. NETGEAR Moderator
        Hello Dino1956
        Have you tried setting the router to WEP connecting the extender than switching it back to WPA2?
        DarrenM
