Maniev
May 22, 2016Tutor
How to add Guest password for Netgear N300 wifi range extender model WN3000RP
Hi, I set up the new Netgear N300 wifi range extender model WN3000RP. I did this primarily to provide better signal for my guests who stay in a room away from the main router. I can connect to the ex...
- May 23, 2016
I figured this out. The extender settings had an option to assign different password for guest, so they are now using the same network, but with a different password.
netwrks
May 22, 2016Master
The Guest WIFI configuration would be set up on your Base Router, not on the extender (the extender only extends your base routers network and configuration). Configure on your base router and then test your setup.
- ManievMay 22, 2016Tutor
Thanks. I did set up the guest wifi on base router, but that has the same low strength signal in the room. That is the reason I added the extender for guests. How do I make the extender extend the guest wifi network, so that guests can use the guest password?
- DarrenMMay 23, 2016Sr. NETGEAR Moderator
Hello Maniev
If you are using your extender to extend your main network you would need a second extender to extend the guest wifi network.
DarrenM
- ManievMay 23, 2016Tutor
