Maniev's avatar
Maniev
Tutor
May 22, 2016
How to add Guest password for Netgear N300 wifi range extender model WN3000RP
Hi, I set up the new Netgear N300 wifi range extender model WN3000RP. I did this primarily to provide better signal for my guests who stay in a room away from the main router. I can connect to the ex...
  • Maniev's avatar
    Maniev
    May 23, 2016
    I figured this out. The extender settings had an option to assign different password for guest, so they are now using the same network, but with a different password.
