Maniev
May 22, 2016Tutor
How to add Guest password for Netgear N300 wifi range extender model WN3000RP
Hi, I set up the new Netgear N300 wifi range extender model WN3000RP. I did this primarily to provide better signal for my guests who stay in a room away from the main router. I can connect to the ex...
- May 23, 2016
I figured this out. The extender settings had an option to assign different password for guest, so they are now using the same network, but with a different password.
DarrenM
May 23, 2016Sr. NETGEAR Moderator
Hello Maniev
If you are using your extender to extend your main network you would need a second extender to extend the guest wifi network.
DarrenM
Maniev
May 23, 2016Tutor
- FIBREOP474Jun 12, 2016Aspirant
FBREOP474 ON NO OPNE AND PASS KEY
