Scooby1994
Mar 19, 2019Aspirant
How to Increase iPad mobile wifi to xfinity
I am trying to figure out how I can get my iPad & or iPhone to connect on the xfinity wifi better when I am mobile. I can pick up the wifi but it is weak. Most times I am just on the outside range ...
Mar 19, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem you currently have?
What is the Mfr and model# of the main host router the NG extender is connected too?
What is the distance between the main host router and the EX unit?
- Scooby1994Mar 19, 2019Aspirant
Not really for the house. I am trying to find something that will work in my truck so when I am mobile I can pick up the xfinity wifi better. Not sure if I posted this in the right spot but didn’t really see any other options.
- FURRYe38Mar 19, 2019Guru - Experienced User
AH, so long haul truck?
Please explain more and maybe we can advise you some.
Do you have a mobile wifi router?
Will need some specifics...
No I do not. Just using wifi built into iPhone and iPad, to pickup the local internet hotspots. Both do have cell service that uses data which I try to avoid since it gets used a lot. I don’t want to have and get a added hotspot or air card since I already pay enough on the plans.
