rowekCSS
Aug 05, 2015Initiate
How to set IP address for WN3000RPv3 and make it keep
I really like my WN3000RPv3. It gets the job done. I did a quick setup which meant I allowed DHCP to set the IP address. Now that I have more time I simply want to set the IP address manually. I ...
Daenerys
Aug 06, 2015Luminary
Did you set the same subnet as the main router? Try turning it off and on after applying the setting and/or set again the IP you would like to set. You may also try updating the firmware if it is not yet on the latest version. Firmware latest version by the way is 1.0.1.24.
rowekCSS
Aug 14, 2015Initiate
Actually, I did. I turned all hardware off and then back on again. No luck. I finally decided to use another browser. The change stuck if I used Internet Explorer. It did not stick with Chrome. Not sure why, but we are now in business. Thanks!
- DaenerysAug 17, 2015Luminary
Yeah, heard the same problem before. But glad to know that it's now okay.
Have a great day!
