thierrybodson
Mar 30, 2020Aspirant
How to set up Bridge mode on my second AC2000 R6850
Hi
I bought two Netgear AC2000 R6850 WIFI Router.
I confirgured the first one and validate everything works fine.
I now want to configured my second WIFI Router as a bridge, to have my WIFI (One unique SSID) accessible from both router, one installed on each level in my house.
How can I do this ?!?
Thanks you,
Thierry
What you want is extender mode. The R6850 doesn't have extender mode.
Bridge mode uses its wifi to act as a router---router bridge and then only the ethernet ports are usable.
If you can hardwire the R6850 in, then you can place it in AP (access point) mode.
- thierrybodsonAspirant
"If you can hardwire the R6850 in, then you can place it in AP (access point) mode"
=> I can wire in my both WIFI router to may main Modem/Router.
In such case, my only solution would be to configure two different SSID, one for each WIFI Router (and so hourse level)
Is that correct ?- plemansGuru - Experienced User
Is that correct ?You can set them with the same ssid. You just have to have the 2nd device in AP mode so you don't have 2 routers controlling dhcp. Since your not using a mesh network (like orbi) devices will tend to be a bit sticky but will roam depending on how old they are. newer devices have newer roaming standards.
