PCB511's avatar
PCB511
How to setup 2 AC750 (EX3700) extenders for 5 Ghz
I'm having a difficult time setting up 2 seperate, AC750 Extenders.
Using Arris TG862G modem (from cable company)
Uses WPA2-PSK
I followed the instructions and it keeps failing for the 2nd one.
I've done numerous factory resets, removing the SSID's from laptop and cleared the browser cache.
I'm using both of the AC750 (EX3700) as extenders (not Access Point).
I want to place them in 2 different locations in the house.
I can't get both of them working at the same time. One of them is setup and working well.
The one that is working has both SSID _2GEXT and _5GEXT
What am I missing, to setup the 2nd one?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello PCB511
    Have you tried to disconnect the first extender when setting up the second?
    DarrenM
    • PCB511's avatar
      PCB511
      I tried both doing both at the same time. (that didn't work)
      I tried doing the 2nd, while 1st one was on (that didn't work)
      I did the 2nd one, with the 1st one off and using the same SSID (that didn't work)
      I did the 2nd one, with the 1st one off and created a new SSID (that worked)
      However, now I have 2 additional SSID (for a total of 4 SSID)
      Extender1 - name1_2GEXT and _5GEXT
      Extender2 - name2_2GEXT and _5GEXT
      name1_2GEXT and name2_2GEXT use the same channels
      name1_5GEXT and name2_5GEXT use the same channels
      Is there a way to get both extenders to use the same name?
      • DarrenM's avatar
        DarrenM
        Hello PCB511
        You can have them both named the same but it is not recommend as it could cause issues.
        DarrenM
