jake_b's avatar
jake_b
I have a netgear wifi extender ex2700 \
I have a netgear wifi extender ex2700 and i connected it to my wifi throught the web and it said it connect succesfully and when i tried to connect to it keeps on saying no internet and i have factory reset it and the issue keeps on happeneing and i have tried wps and that does not work. Please i need help.
OS: Windows 10
  • plemans's avatar
    What modem/gateway do you have?
    What router are you connecting it to?
    What firmware is on the extender?
    • jake_b's avatar
      jake_b
      I have a modem that is a netgear one, I don’t know which firmware it’s on and I’m connecting it to an asus router.
      • plemans's avatar
        Well, that wasn't at all helpful.
        Which netgear modem?
        What asus router?
        The firmware is found on the status page of the extender. If you did try installing using the installation assistant, you'd have seen it on that page. Did you actually try installing using the installation assistant?
