helen2000's avatar
helen2000
Incorrect Wifi Password on N300 WiFi Range Extender Model EX2700
I followed the instruction to connect with WPS (my existed internet is Bell Modem White 4000), and all the lights (Power/WPS/Router) are solid green. And I also checked that there is excellent signal of my Ex2700. However, only when I input the same WiFi password that I use for my WiFi router, it doesn't work and says 'incorrect password'. What should I do? Please kindly advise. Thanks!
  • plemans's avatar
    Sep 01, 2022
    glad you got it working! you might mark it solved so others aren't still trying to solve it.
  • plemans's avatar
    Try factory resetting the extender and setting it up using the installation assistant and not using WPS
    • helen2000's avatar
      helen2000
      Thank you! I called customer service technical support with the guidance of reset by using installation assistant, and then make the extender working finally.
      • plemans's avatar
