daytooner
Jul 08, 2014Tutor
Install after factory reset - won't stay connected
I've had my extender for quite awhile - a year or more. I had it set up and connected it to my Netgear wndr3700 router and all ran fine, until now. Nothing can connect to it, and I can't access it ...
daytooner
Jul 08, 2014Tutor
jmizoguchi wrote: Did you try with WIFI on pc disable if you have one ?
Yes. I tried every possible combination one could think of.
Read my post (as well as all of the other posts) in the thread I mentioned above . That will describe the problem more thoroughly.
ken
