bbon
Jul 22, 2012Aspirant
Install failure with DLINK DIR-615 wireless router
I recently bought a WN2000RPTv2, to extend my wireless LAN to the far end of my home. Problem to be addressed is that the wireless signals do not propagate very well through our adobe brick walls! ...
bobhirschfeld
I'm having similar problem with the same combination of D-Link and Netgear that you are using. I got the extender to work, but it seems that every 24 hours or so, it stops working. The only way to restore service is to unplug the D-Link and let it restart. It automatically reconnects to the Netgear extender and continues to work for another day or so. I've had the D-Link for a few years and never had it fail like this until I installed the extender. I don't know if this helps you, or points out some sort of incompatibility between the two products.
