Mekawi44
Sep 11, 2016Aspirant
Installation of WN3000RP Using Ethernet Cable
My router N900 router is installed in the basement. Signal is too weak to cover the entire house. I need to install the range extender on the second floor as placing the extender on the first floor p...
TheEther
Sep 11, 2016Guru
You need a range extender that supports AP (Access Point) Mode. It seems that WN3000RPv3 supports it. I'm not sure about the older versions.
Any other Netgear range extender will work, except for the EX6120 and EX2700. Check the online manual to be sure.
A router will also work. Some models have an AP Mode setting for easy setup. Those that don't can still be used by disabling the DHCP Server and connecting through a LAN port.
