kbell
Mar 12, 2014Aspirant
ipad connection
my ipad2 can no longer connect to my WN2000RPTv2 EXT network. When I enter the password on the ipad I get an "unable to join" network message. The ipad has, in the past, been able to connect. please...
WizardJ
Mar 12, 2014Luminary
If the iPad is the only device not able to connect to the extender, I would suggest first trying to forget the network. Go to Settings -> Wi-Fi, find your extenders network and then press the blue "i" symbol (or arrow symbol) to the right and then push Forget this network. Now try connecting to it again.
If no devices at all can connect to the extender, or if the above suggestion is not helping, then you should consider resetting the extender to its factory default settings and reinstall it. Check the extender manual for this, or contact Netgear support.
Good luck. :)
Good luck. :)
