stillwaterdave
May 27, 2013Aspirant
iPad defaults to the main WiFi network name, which is too weak
Is there a way to keep the iPad from default connecting with the weak main WIFI network name instead of the stronger 2G and 5G signals? Assuming the iPad connects to the first SSID it finds that ...
jmizoguchi
May 28, 2013Virtuoso
Don't connect both so that ipad will use BOTH.
remove one of the band of the ipad wifi list ( Forget this network)
