MelRaff
Mar 19, 2012Aspirant
iPhone & iPad unable to connect
I have a WNDR3700 router, which has been working OK for a few years now, but it does not provide adequate coverage in my (small) house. So I just bought a WN2500RP extender for that purpose. My wire...
Jeffrey07
Apr 10, 2012Novice
Hi MelRaff,
It is possible that your WNDR3700 and WN2500RP is just connected using 5Ghz and your computer is the only one that has a 5Ghz wireless adapter. Try Pressing the WPS button again from the WNDR3700 and WN2500RP for it will let the WNDR3700 and WN2500RP connect using 2.4Ghz. If that still does not work. Check if your iPhone and iPad if it still connects to the main one. Please provide also your current settings for both WNDR3700 and WN2500RP.
