Kelbra813
Sep 06, 2015Follower
Iphone5 and WN2000RPT range extender
Lately the connection keeps dropping, when it used to work fine. It works fine with computer and Amazon Prime TV
- Sep 07, 2015
Could you try changing the wireless channel of the router/extender, for the 2.4GHz band channels 1, 6, and 11 are typically the best choices? Are you using the 2.4GHz or 5GHz band?
Babylon5
Sep 07, 2015NETGEAR Employee Retired
