JHMSupport
Sep 15, 2021Aspirant
iPhones will not connect to EAX20 AX1800
Anyone else having trouble with Iphones not connecting to EAX20 running the latest firmware 1.0.1.62_1.0.103? At our site Iphone 11 pro max running iOS 14.7.1 will not connect to extended 2G or 5...
- Oct 04, 2021
Update and resolution.
At our marina, three EAX20 that extend a Ubiquiti Unifi network failed to allow iPhones and iPads to connect, starting around 2-Sep-21. The Apple devices report No Internet when selecting the EAX20's SSID. Other devices connect without issues.
Previously the same iPhones connected to EAX20 with firmware V V1.0.0.58_1.0.101 without issues. Rolling back the firmware from V1.0.1.62_1.0.103 to the previous version does not resolve the issue.
I suspect one or both of these causes
- Apple update(s) to their devices created the issue
- Factory reset and rollback of EAX firmware did not reproduce the configuration that previously worked
Replacing NetGear EAX20 with GL.INET's GL-AR750-Ext model Slate resolved the issue.
JHMSupport
EAX 20s using different SSID and password than external WiFi. EAX 20s using same password for extended 2G and 5G.
Sep 15, 2021Guru - Experienced User
its only iphones with the issue?
Have you went into the iphones and forgot password/network option and reconnected?
