The_Hobbit
Jul 13, 2012Aspirant
Is it possible to WIRELESSLY connect the WN2500RP to the Airport Extreme?
Hey guys! I'm new on these forums, so pardon me if this has been asked before. Anyway, I'm looking forward to buying the Airport Extreme, and use it as my main router, and I was wondering if my cu...
The_Hobbit
Jul 15, 2012Aspirant
alienjiz420 wrote: I was wondering this myself and found the answer in one place, on a review of the WN2500RP
source: http://www.amazon.com/Netgear-Universal-Range-Extender-WN2500RP/product-reviews/B006V72AHC?pageNumber=2
"Arrived on time in excellent condition. The extender was easy to set up and solved my problem of having weak signals upstairs because the Airport Extreme N router was downstairs."
I'm assuming you just go to manual setup on the airport, click the wireless tab and check "Allow this network to be extended"
you'll probably also need to do some configuring on the netgear end. i'm going to order one of these soon i'll post my results
Yeah, I didn't experience any problems setting up the extender, it works perfectly with my Airport Extreme!
