MGB19
Jul 14, 2014Aspirant
Is the WN2000RPTv2 a repeater
Hello I have a WN2000RPTv2 and have linked it to my wifi network. A PC connected via a cable can use the extender to connect to the internet, however non of the other devices on the LAN are accessibl...
Lawrosa
I have the same issue.. was on support with netgear and they were no help... Seems the ext I bought shows two SSID. If I bought another router the you have one ssid and security features are easier to set up as you use the main router. WPA and mac filtering is a nightmare with the extender IMO...
