Tsar_maximilian
Oct 02, 2025Aspirant
Linking mismatch with two EX80 nighthawks
I have 2 nighthawks, one is Ethernet connected to the router and the other is linked to the connected AX6000 nighthawk via an Ethernet cable. Essentially they are daisy chained to each other.
The first AX6000 is setup via the nighthawk app but the other one will not let me add it to the app. It appears as”NETGEAR_EXT” and when I do the setup, I connect to WiFi called the same, run through the setup, but get to a point where the setup “cannot connect to NETGEAR_EXT”. I’m sat right next to it, it shows power light is white, WiFi light is white, 2.4 GHz light is white and the Ethernet port 1 ( where it is connected to the other AX6000) is also white.
What is wrong with this ? Why can’t I get it setup up correctly ?
- Tsar_maximilianAspirant
I have 2 nighthawk AX6000 seems to be stuck in a weird mode. I assumed it was a router mode but no matter what reset I do, factory reset included. When it turns on after the reset it doesnt go to the normal login format 'NETGEAR_EXT', instead it just says 'NETGEAR' and refuses to let me login. I dont understand why and it feels as if there is something wrong with the nighthawk.
Thanks everyone for the help, I believe this is the fix and I have managed to get one of the EX80’s in AP mode! However the other one is stuck in bloody router mode. No matter what I do to reset. It refuses to launch in NETGEAR_EXT mode for me to set it up
EAX80 only has AP or Extender mode. There is no router mode.
Press the reset button on the other EAX80 for 15 seconds then release. Give about 2 minutes then look for the wifi signal or set it up using a wired PC.- Tsar_maximilianAspirant
Hey! I reset the extender a million times with the instructions about, unfortunately though it goes to 'NETGEAR' and wont let me connect through wired or wireless. Im not sure too much about the wired connection step though. Mainly because when I put the ethernet cable into the extender it refuses connection unless it is tethered to the main router.
FURRYe38 is correct. when hardwired they need to be in access point mode. Shut one off and go through its setup first (making sure to select access point mode), then once its setup, shut it off and setup the other one. I'd recommend the installation assistant over using the app for this setup.
Should be a pretty awesome setup with 2x of them daisy chained with a hardwired backhaul. Just keep in mind that devices will be a little more "sticky" setup in access point mode versus a traditional mesh setup. But it should still be darned quick.
What is the brand and model# of the main host router?
You have two EAX80s?
Does setting up the first extender with the host router work? Does this have a different SSID name network?
Is the first extender running in AP mode?
What distances are in between the two extenders?
Size of home in sq feet please.
What is the brand and model# of the main host router? - TalkTalk Wi-fi Hub
You have two EAX80s? - I have two AX6000 nighthawks, these are linked to each other by an Ethernet cable and to the WiFi hub
Does setting up the first extender with the host router work? - Yes, the first one is set up and has both 2.5GHZ and 5GHZ connection available
Does this have a different SSID name network? - It does, to understand which one I was connected to I kept the router name the same but the AX6000 that connected is called TalkTalk_UpstairsIs the first extender running in AP mode? - I don’t know what AP mode is so I guess no
What distances are in between the two extenders? - I don’t know the answer to this but surely Ethernet cable doesn’t require a distance ? I will guess by saying around 2000 square foot Victorian house
The maximum distance is 100m (~328 feet). But I think FURRYe38 is focused on the wifi performance.
AX6000 is a speed rating, so it doesn't clearly identify what you have.
Do you have two EAX80s (which is an Nighthawk extender), or do you have two RAX120s (which is a Nighthawk router)? Both are labeled as AX6000.
If you have the routers they should be in AP (access point) mode - which is setting them up to run as extenders.
