cireland
Sep 16, 2018Aspirant
Literally no upload speed on wired AC3000-Nighthawk X6S Tri-Band WiFi Mesh Extender
Hi,
So I am having issue with the extender actually have been for ages with constant disconnects , anyhow that is not the main problem (which I think I fixed by going back to default firmware.)
The problem; my upload speed is nonexistent, speedtest.net is doing the download fine, circa 150mb but when it comes to upload says I am not connected to the internet, when I try other speed testers it is giving me upload speed of 0.1 or 0.2mb which is obviously not right - this is over a wired connection.
I have tried different firmware, I have tested the connection on my phone over WiFi and tested the PC over WiFi and my upload is fine. i.e about 18-20mb. (although by download is a lot lower circa 65mb - I have also tried without using the netgear extender and just using my virgin router and despite slower downloads I am not having any issues with the upload speed.
Any suggestions highly welcomed!
Thanks
Chris
Thanks
Chris
- cirelandAspirant
Hi
Thanks
Chris- StephenBGuru - Experienced User
When you say the EX8000 is "wired", do you mean that it is wired to the router (using AP mode)? Or do you mean that you are connecting a PC to the EX8000 LAN port (using extender mode)?
Also, what router (manufacturer+model) are you using?
- cirelandAspirant
Sorry, I should have been clearer when I say wired I meant connected via ethernet to the PC.
So EX8000 is connected via my router via wifi and then I connect the EX8000 via ethernet to my PC.
