EZ123's avatar
EZ123
Looking for a device which wiil enable me to establish a local network
Hi,
I'm looking for a device which will enable me to:
1. Establish a local WiFi network, and connect several mobile devices to a this local network (no internet connection needed)
2. Outdoors, where there's no WiFi available
3. Use an app (which I'm developing) to transfer data between these devices over TCP/UDP
Is any of these devices suitable?
http://www.netgear.com/home/products/mobile-broadband/hotspots
http://www.netgear.com/home/products/networking/wifi-routers/PR2000.aspx
Appreciate your help,
EZ
  • If you are willing to sacrifice wireless security and don't need a lot of bandwidth, you can just use a Windows or Mac laptop to create an ad hoc Wi-Fi netework.
    Since you have no need for Internet access, I would not recommend the mobile broadband hotspots.  You'd be wasting money on the unneeded cellular modem.  But come to think of it, if you have a smartphone with hotspot enabled, you could use it as a local network.
    You didn't specify the range required for your outdoor Wi-Fi network, but any of the Wi-Fi routers should work.  The PR2000, being a travel router, may work only over short distances.
    • EZ123's avatar
      EZ123
      Thanks for answering.
      Some more input:
      1. Security is not an issue
      2. I do need a lot of bandwidth, and quite a lot of devices (couple of dozens), although for start few devices will do fine
      3. I prefer not to use a laptop, since I need a mobile and lightweight solution
      4. I need a range of about 10m radius
      5. I guess that a smartphone with hotspot enabled won't be enough for a lot of bandwidth and more than a few devices...
      Appreciate any solution that could meet these needs :)
      • How much bandwidth do you need per device?
        Do you have any idea if the devices can do 5 GHz or will they be 2.4 GHz only?
        Since this is outdoors, is A/C power available?
