ErgoBlue
Sep 01, 2023Follower
Looking for wired mesh compatible with R7800
I currently own a R7800 Nighthawk X4S router which provides inadequate wifi coverage. I am looking for wired access points that will allow for seamless roaming between the equipment. One SSID, on...
Sep 01, 2023Guru - Experienced User
The R series routers are not MESH supporting. If your looking for something that supports MESH specifically, then Orbi or Nighthawk MK systems all support MESH.
