KrisStarling
Sep 02, 2015Aspirant
Looking to extend the signial strengh from my houe out to my pool area.
I have a Netgear N600 WNDR3400 in my office which is located down stairs(Basement area). This router reach up into the second floor well. It is connected to a Netgear WN2500RP Extender to extend the ...
- Sep 10, 2015
Hi KrisStarling,
The extenders listed above are home products that are available through vendors such as Amazon.
The WN25000RP will not function properly when ethernet to router. However the extenders listed above will connect ethernet to router when set to access point.
Please see page 23 of 86. http://www.downloads.netgear.com/files/GDC/WN2500RPV2/WN2500RPv2_UM_28May2014.pdf
The enclosure might work depending on thickness.
KrisStarling
Sep 10, 2015Aspirant
Are the EX3700, EX6100, EX6200 extenders NetGear products. Comercial??
nhann
Sep 10, 2015NETGEAR Employee Retired
Hi KrisStarling,
- KrisStarlingSep 10, 2015Aspirant
I really appreciate your help. I am goiong to try and move the extender further from the router and closer to the pool area. Limited by the Wifi signal it uses to connect back to the router with. If I can not get this then I will need to upgrade to a different model where I can hard wire the extender back to my current Router where the new extender would be set up as a Access Point. From that I could connect an atena directed towards the pool area.
