MadHolms
Jul 12, 2014Aspirant
Looses connection
Hi, I have the EX6200 working in FastLane mode where it connects via 5Ghz to my router (AirPort Extreme last generation) and then using wires I connect some other stuff to it. Well, all this works...
EtheB
Feb 02, 2015Aspirant
Did they have you go through the whole re-flash, factory reset & reboot process?
I'm curious given it seems I "was" having the same problems and have now passed the 10 day mark, whereas previously I'd be really lucky to last a week.
Between when you'd purchased, and when you began having problems, had you upgraded the bios at all?
