MadHolms
Jul 12, 2014Aspirant
Looses connection
Hi, I have the EX6200 working in FastLane mode where it connects via 5Ghz to my router (AirPort Extreme last generation) and then using wires I connect some other stuff to it. Well, all this works...
DigitalMaestro
Feb 05, 2015Star
Yes , they had me go through the reflash, factory reset and reboot procedure. When I bought it I upgraded to the latest firmware at the time. Given that you are not having problems anymore can you provide your configuration details so I can see if I can duplicate your success?
1. Firmware version
2. Fastlane or regular extender mode
3. If Fastlane then which radio provides the backhaul?
4. What bandwidth is each radio set to?
For reference, here are my details:
1. 1.0.0.52
2. Fastlane
3. I use the 5Ghz as backhaul to the router, 2.4Ghz to the wireless clients
4. 2.4Ghz radio bandwidth is set to 300M, 5Ghz to 600M
Cheers
DM
1. Firmware version
1. 1.0.0.52
2. Fastlane
Cheers
DM
