MadHolms
Jul 12, 2014Aspirant
Looses connection
Hi, I have the EX6200 working in FastLane mode where it connects via 5Ghz to my router (AirPort Extreme last generation) and then using wires I connect some other stuff to it. Well, all this works...
EtheB
Apr 04, 2015Aspirant
SimonNWalker wrote: +1.
Same problem and everything I've tried won't fix it.
When you say "everything" have you gone the full reset to scratch process as described in painful detail earlier in this post?
I am not making any apologies for Netgear service but since I initially went several rounds with their tech support & subsequent suggestions (including up to L2 support), the final outcome has (almost surprisingly) been an extender that has been rock solid for months now.
So much so I'm not game to make any further changes to it :-)
