MadHolms
Jul 12, 2014Aspirant
Looses connection
Hi, I have the EX6200 working in FastLane mode where it connects via 5Ghz to my router (AirPort Extreme last generation) and then using wires I connect some other stuff to it. Well, all this works...
lurzan
Apr 20, 2015Novice
EX6200 Firmware Version 1.0.1.60_1.1.98
New Features and Enhancements:
Added wireless 2.4G JP Country code and whether channel Ch120~128 for JP region.
Updated firmware for new hardware change.
Updated wireless driver to fix 5GHz interface with Access Point mode scan fail.
Fixed fail to assign IP address to Ethernet LAN after reset.
To Upgrade
Note: To avoid wireless disconnect issue during the firmware download process, NETGEAR recommends that firmware upgrade be performed on a computer with wired connection.
Write down all the settings which you changed from the default values, since you may need to re-enter them manually.
Download and extract the new firmware to a convenient place such as your desktop. The filename after extracting is EX6200-V1.0.1.60_1.1.98.chk
Log in to the device using a Web browser. The URL is http://www.mywifiext.net.
Click Maintenance > Firmware Upgrade
Click Browse and find the file you just downloaded.
Click Upload. While the firmware is loading, do not interrupt the upgrade process.
