MadHolms
Jul 12, 2014Aspirant
Looses connection
Hi, I have the EX6200 working in FastLane mode where it connects via 5Ghz to my router (AirPort Extreme last generation) and then using wires I connect some other stuff to it. Well, all this works...
WinterMute
May 19, 2015Star
I had this problem and another one--that any time an Ethernet cable was plugged in, the physical connections slowed to impossible speeds (typically 0.1Mbps). I did a lot of troubleshooting before engaging support, and then together we did the whole routine: other firmware versions, factory resets, remove and re-add network adapters on all clients. I've done FastLane/no FastLane.
For now I've got a replacement coming my way. We'll see if that fixes the problem. It's critical for me because the EX is my link to my home office and I have to do some late-night WFH stuff to manager servers and code.
I'm hoping this problem is fixed with a new unit--reading this forum doesn't give me a ton of hope. If it *doesn't* fix the problem, I'll post back here if I learn anything.
- Zakko79Aug 20, 2015Initiate
Hi,
same problem with one of my two EX6200, every day drops the 2.4 GHZ connection,
I have the latest firmware V1.0.1.60_1.1.98
Rebooting fixes the issue for another day....- Wingman33Sep 03, 2015Aspirant
I've had exact issues as everybody else and have not found a solution. This thread looks like it goes back as far as the day it was released. I simply can not believe there has been no solution to this problem from the manufacturer. How does Netgear get away with this?.... It should actually be illegal for them to be selling this s*#@.
- nhannOct 14, 2015NETGEAR Employee Retired
Please see the following discussion on the EX6200 connection issue:
https://community.netgear.com/t5/WiFi-Range-Extenders-Repeaters/EX6200-drops-2-4GHZ-connection-every-day-or-so/m-p/990140#M10481
