Hybr1dz
Aug 04, 2013Novice
Losing internet connectivity with WN2500RP
Recently bought a WN2500RP and the initial setup was a breeze. I am able to connect to the extended WiFi, browse the internet, etc. However, after approximately 30 minutes (sometimes an hour or so, bu...
Hybr1dz
Aug 05, 2013Novice
Simply powering off/on does temporarily fix the problem, but moments later I get the "Limited or no connectivity" message.
Yesterday, I've noticed that the problem seems to be related to assigning IPs. When I have one device connected and using the internet, I would try to connect a second device and this device would have a hard time obtaining an IP. Eventually, I can get an IP and use the internet on this second device, but then my first device loses internet connectivity. Seems something is wrong with the DHCP of my router although it seems to function fine when I connect directly to it.
I played around with my router settings and I changed it's "Switch Mode" from IPv4+IPv6 to simply IPv4. This also forced the router to reset itself (I do not have physical access to it, otherwise I would've tried earlier). And so far, I am seeing no problems connecting to the repeater for all of my devices and it's been this way since overnight. Hopefully, that was the trick.
