anxh
Dec 31, 2017Tutor
Macbook pro connection to ex6150
I cannot connect my macbook pro to the EX6150 extender. I am the UK and just upgraded by homw hub from a BT Hub 4 to a Hub 6. The connections through the 4 worked fine and my Amamzon Firestick and iPhone connect fine to the EX6150. My macbook did too temporarily but not now. It shows as being connected. I have factory reset the extender several times without success. Any advice please? Thanks
- DarrenMSr. NETGEAR Moderator
Have you tried to remove the network from the macbooks wireless settings then connect to it again?
DarrenM
