anxh's avatar
anxh
Tutor
Dec 31, 2017
Macbook pro connection to ex6150
I cannot connect my macbook pro to the EX6150 extender. I am the UK and just upgraded by homw hub from a BT Hub 4 to a Hub 6. The connections through the 4 worked fine and my Amamzon Firestick and iPhone connect fine to the EX6150. My macbook did too temporarily but not now. It shows as being connected. I have factory reset the extender several times without success. Any advice please? Thanks
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Have you tried to remove the network from the macbooks wireless settings then connect to it again?
    DarrenM
    • anxh's avatar
      anxh
      Tutor
      And very odd, as Amazon Firestick, Satellite TV box and iPhone all connect and load/stream fine through the Netgear Extender - just not my Macbook.
    • anxh's avatar
      anxh
      Tutor
      Hi - yes and thanks. I have tried that but it doesn't work.
