Cirus
Feb 27, 2018Follower
Model: EX7500 NOT SEEN ON COMPUTER
Purchased just a few days ago, Plugged into power all LED's blue and firm except 2.4Ghz
solid amber.
Unit does not connect to router
Does not come up on list with NETGEAR.EXT
1 Reply
- jvasanth1984Virtuoso
Hi Cirus,
Perform reset and try to look up for NETGEAR_EXT. You can setup the device by the help of below links and check lights on it based or the article shared.
https://kb.netgear.com/000044738/How-do-I-set-up-my-Nighthawk-Tri-band-WiFi-Range-Extender-using-WPS
