GeorgePetter
Mar 08, 2020Aspirant
Motorhome WiFi Extender
Looking for a Campsite WiFi Extender. Aerial on outside of metal body of motorhome. Receives Wifi then amplifies the signal and re transmits the signal via an aerial inside metal body of van. Not a phone booster just simple wifi that is free for use on a Campsite. Metal bodied motorhomes reduce wifi signal. Due to metal body...Not sure what product I need. Also it has to be 12Vdc
- DexterJBNETGEAR Moderator
Hi GeorgePetter, you check the link below for our WiFi extenders.
https://www.netgear.com/home/products/networking/wifi-range-extenders/
Dexter
- GeorgePetterAspirantIt's all very all of the extenders. But so far there isn't one that runs from 12Vdc. Many are 110vac or 230vac. That I have found. Also it from outdoors to inside a motorhome. Not room to room extension booster.
- GeorgePetterAspirantNot found an outdoor to indoor extender 12vdc. Most are room to room extender
Hi, you may want to look into the outdoor Orbi linked below.
https://www.netgear.com/orbi/rbs50y.aspx
Dexter
