wtyoung18
Dec 06, 2021Initiate
Moved EX6150v2 extender, the power is on but will not setup
I recently purchased an EX6150v2 extender, I set it up on one side of the room, but had to move it. So, I plugged it into another wall in the same room. The power light is on but will not setup. I even attempted a factory reset and that didn't work. Any help would be greatly appreciated. Thank you.
Only the power light is in and its amber?
Seems like a corrupt firmware issue.
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
