jeremywearsvans
Nov 18, 2020Follower
MR63 "Check Ethernet Cable" Nighthawk WiFi 6 Mesh Internet Router
Hello,
I got the Nightawk Mesh WiFi 6 MR60 router with the two satellites. When I plug it in and run the setup I get "Check your ethernet connection"
I'm plugging it into at Cisco DPC3008 Docsis 3.0 modem from Spectrum (it's a bit of a dinosaur).
I checked that I'm plugged into the "Internet" port on the back of the router. I've rebooted and factory reset and it's still giving the same error. I waited on hold for over two hours to be hung up on when I finally got tech support. Hoping someone here can assist.
Thank you in advance!
-jeremy
No RepliesBe the first to reply
