Janeca
May 12, 2015Follower
Multiple Range Extender WN3000RP ?
Hi I have a simple question. Can i use more then one Range Extender WN3000RP(Or another Range Extender) on the same Network? Thank you Janeca
Fairytail
May 27, 2015Virtuoso
If you connect the 2nd extender to the main network that would be ok. If 2nd extender is connected to the 1st extender, its possible but expect a slow connection.
