Janeca
May 12, 2015Follower
Multiple Range Extender WN3000RP ?
Hi I have a simple question. Can i use more then one Range Extender WN3000RP(Or another Range Extender) on the same Network? Thank you Janeca
Fairytail
Jul 06, 2015Virtuoso
That I am not sure of as it depends on the environment. If the connection from the 1st extender is cut into half then probably can get 1/4 or less with your subscribe speed.
