sgsmiles
Jan 27, 2018Follower
my extender causing my router to go offline
My 6000 series router connects to the internet and other devices fine. When I begin the connection process for my extender 6150 all connection to the router and all devices is interrputed. The only way to re-establish connection is to disconnect the extender.
1 Reply
- DarrenMSr. NETGEAR Moderator
You may try to factory reset the extender and make sure it is using the latest firmware. To factory reset hold the reset button for 10+ seconds.
DarrenM
