GeorgieNg080459
May 10, 2018Aspirant
My extender isn't accepting my WiFi password?
My extender can connect to the router, but when i take plug it into an area in my home, and try and connect using a device, using the same password as my router, it doesn't recognise it. Can someone ...
DexterJB
May 16, 2018NETGEAR Moderator
Hi GeorgieNg080459,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
GeorgieNg080459
May 17, 2018Aspirant
Hi Dexter,
Thanks for your response.
The firmware version is Model: WN3000RPv3|N300 WiFi Range Extender. What i am having problem with, is the password to my router isn't the same when input it into the extender, once on the same wifi. Wondering how to find out the password to the extender as it isn't the same.
Can you help me please?!?! I don't know what else to do.
