GeorgieNg080459
May 10, 2018Aspirant
My extender isn't accepting my WiFi password?
My extender can connect to the router, but when i take plug it into an area in my home, and try and connect using a device, using the same password as my router, it doesn't recognise it. Can someone ...
DexterJB
May 16, 2018NETGEAR Moderator
Hi GeorgieNg080459,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
DexterJB
May 21, 2018NETGEAR Moderator
Hi GeorgieNg080459,
As mentioned on the previous post, you can temporarily hardwired a computer to the extender and access the UI to confirm the password. If that does not work, you can try doing a factory reset and go through the setup again making sure you got the correct password.
Dexter
Community Team
