oliveryue2
Aug 22, 2015Aspirant
My ip address doesn't show up anymore, even after reset
I have a old wg602 router. I hard reset it because I couldn't connect to it. I know it sucessfully reset because the SSID reverted back to Netgear. The default ip address printed on the router is 19...
VE6CGX
Aug 22, 2015Master
ipconfig command has many switchs one example is /renew /all , etc.
Tried command with various switches?
- oliveryue2Aug 23, 2015Aspirant
Yeah I have. I tried releasing, and renewing already. I don't see too much information need in /all, but I 've done that too already/ I've tried reinstalling my network card itself. But as stated before, the problem lies with the router itself and not my network card, because I have other routers that work just fine with said computer/network card. So what I really require is a way to access the router's setting itself. That's all I need to get going, because then I can modify the router itself. However, if one can't access the router in the first place, there would be no solution. Unless, there is some way to utilize command prompt to change settings within the router? It seems that this is not possible though. Any help is appreciated. Also if this is the death of my router, I can accept that too. I just want to make sure before I chuck it in the bin.
- VE6CGXAug 23, 2015Master
Tried switch /flushdns? Turn off router, push and hold down reset switch, turn on the router,
when power indicator flashes let go the reset switch, wait until router does it's thing reboot and
come up ready, any change?
I tried turning on the router while holding the reset button like you said. Same old. Also flushed my DNS cache, still no good.
