jcaboose
Oct 04, 2015Follower
N300 - Limited Access Only
I just got an N300 and followed the instructions in booklet. I plugged it in to the outlet closest to my router. I used a tablet to establish the "EXT" to my current wireless network. So far, so good...
nhann
Oct 05, 2015NETGEAR Employee Retired
Hi jcaboose,
Which N300 WiFi Extender are you using?
Which router is connected to it?
Are both the extender and router updated to latest firmware?
Please try to connect to the extender network with your Tablet in the same area as your PC. Is it showing limited connection?
Also change your WiFi channel :
